1. soph8's Avatar
    This is for SPRINT ...We got the intercept with the 2.1 and I was really liking it. Now with thte 2.2 update it really SUX. So many issues! I have exchanged it for new one just in case. At least blue tooth works part of the time now. Before was paired and nothing. No connecting. Now, 30%. That's with multiply sets. Other probs are black screen during calls or making them not able to do anything. non responsive. Black & white at top where notifications are. Volume weirds out most of time for notifications and ringer. Or during a call. Sound muffled. Just having real bad problems and don't like the update at all.
    Would love to hear other thoughts......
    Sincerely,
    D~
    02-12-2011 11:16 AM
  2. ratsttam's Avatar
    Have had pretty much nothing but good things with the 2.2 update. It initially failed the install back in December (Sprint halted the push that same day), but installed fine with the update.zip file that I found for it.
    Move what you can to the SD card under "manage applications" to free up a pretty good chunk of memory.
    Can't say much about BT not working most of the time, I've never had luck having it work properly on any phone besides my old Sanyo Katana DLX, and BB Pearl.
    The only things I didn't like was the removal of the black notification bar, and the removal of the quick toggle (wifi/bt/brightness) at the top of the notification pull down. 2.2 has been a LOT faster, seemingly more stable. I much prefer the horizontal swipe unlock.
    02-15-2011 07:17 AM
  3. soph8's Avatar
    Thanks for the reply....
    "The only things I didn't like was the removal of the black notification bar, and the removal of the quick toggle (wifi/bt/brightness) at the top of the notification pull down. "
    I agree......
    " I much prefer the horizontal swipe unlock. "
    I like the old 2.1 for so many things. Like you could have it unlocked as an option. Also a short cut on home was so much better to create! Am having a hard time with things I got used to. Do you know of a update manual for it now?
    I am slow sometimes so could have missed it~ LOL!
    Yes, have been doing that to free up memory.
    Thank you for all your suggestions.
    02-15-2011 09:28 AM
