1. larryg's Avatar
    Just started using today, did my first transaction with the clerk insisting it wouldn't work and exclaiming after a few seconds...."wow...it went through". So far so good except.....my battery has drained faster today then in recent memory. Anyone else experiencing this?
    10-21-2015 04:04 PM
  2. me just saying's Avatar
    I do not notice any battery draining with samsung pay. It is always running in the background. maybe give it a few days to see if it continues to drain since today is your first day using it.
    10-21-2015 05:21 PM
  3. ucsdsig's Avatar
    No negative impact on my battery life at all. Been using the app since Saturday.
    10-21-2015 07:09 PM
  4. radyoactive's Avatar
    I noticed yesterday that my battery was pretty low before leaving work yes. I did a reboot this morning and things seem better.
    Sent from my SM-G928V using Tapatalk
    10-22-2015 03:07 PM
  5. Mr_Bugman's Avatar
    I've been leaving NFC and Simple Pay turned on, using Spay at least 6 times a day, and haven't noticed any battery life differences.
    10-23-2015 09:00 AM
  6. chonghak's Avatar
    Yes, this is with Verizon. I noticed a significant battery drain since the Vz update + S Pay a couple of days ago. I turned off "Simple Pay" option which lets you swipe upward from any screen to see if it makes any difference....
    10-23-2015 10:23 AM
  7. cohoman's Avatar
    I normally leave NFL turned off on my S6, and Samsung Pay automatically turns NFL on when I activate and use it, then turns it off.
    10-23-2015 10:58 AM
  8. r56mcs's Avatar
    My cm security app does not recognize sp app as battery drainer.
    10-23-2015 11:05 AM
  1. Replies: 4
    Last Post: 11-13-2015, 11:01 AM
  2. How do you get to quick access on a Samsung Galaxy S6?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 10-21-2015, 04:03 PM
  3. Replies: 0
    Last Post: 10-21-2015, 03:46 PM
  4. How to root a US Cellular Samsung Galaxy S4 without a computer?
    By Tater1408 in forum Samsung Galaxy S4
    Last Post: 10-21-2015, 03:20 PM
  5. Replies: 0
    Last Post: 10-21-2015, 02:57 PM
