Will I have to enter my PIN# whenever I use my Bank of American debit card on Samsung Pay? Thanks!
If you are not using the fingerprint authorization for Samsung Pay, you have the option of using a 4 digit pin. Not your BOA pin #, but the optional pin authorization within the Samsung Pay app.
Yes, its just like swiping your card. The card reader doesn't know you used SP. It thinks you swiped a card. If you need PIN + Cash back? + Amount ok? on a real card, you'll need all that on SP.
I'm sorry, but I probably didn't make it clear. I've tried this after several different stores. I only have one BoA debit card on my phone.
If I use Samsung Pay to pay using MST(the machines doesn't have touch to pay), it ALWAYS asks me to enter my PIN#. At a couple of store including Walmart, after I enter the PIN#, I'm asked to sign my name as well. Then the receipt gets printed out.
If I take the actual BoA debit card and swipe normally, the transaction is approved and the receipt gets printed out.(half the time the machine doesn't even ask me to sign)
That's why I'm confused.
