1. 1999ws9's Avatar
    I'm rooted and I have a 32gb card and yet I am out of space to install any more apps and can't update the stock software that came with the phone.
    My Link2SD shows this:
    /data Total: 161MB Used: 143MB Free: 17.81MB
    /mnt/sdcard Total 28.64GB Used 1.58GB Free: 27.05GB
    /data/sdext2 Total: 0.89GB Used: 65.76MB Free 850MB
    /system Total: 161MB Used: 159MB Free: 1.93MB
    /cache Total: 93.76MB Used: 356KB Free: 93.41MB
    I tried to use MiniTool Partition Wizard thinking I could enlarge the partition but all I see is one primary Fat32 on the sd card.
    How can I increase the size of the partition that I cannot see?
    09-10-2012 01:38 PM
  2. ciscogee's Avatar
    I don't think your on data is on ur sd card.
    Adb shell or emulator
    Su
    #cat proc/partitions to see what's where.
    Also are your partitions systems correct?
    Refer to firehaks pdf.
    Also you would need sd-ext on kernel. (I'm working on adding it to dmrlook s kernels)
    Ill be in irc
    Sent from my SPH-M580BST using Tapatalk 2
    09-10-2012 03:17 PM
  1. I think my phone is still dropping data
    By trigun123478 in forum Verizon Droid Charge
    Last Post: 12-13-2011, 05:28 PM
  2. MiniUSB Cable That's Supplied is Too Small
    By SkyeHack in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 09-21-2011, 12:43 AM
  3. I think my phone is bricked. Android system recovery <2e>
    By mcote1080 in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 06-04-2011, 08:20 PM
  4. I think my phone's filesystem is corrupt
    By JerkyChew in forum General Help and How To
    Last Post: 04-25-2011, 12:53 AM
  5. I think my wife is cheating on me??
    By Mr Mayor in forum The Android Central Lounge
    Last Post: 06-09-2010, 03:36 PM
