Re: help with usb debugging
are u booting into CWM recovery (hold 'U' while booting)? it should say cwm somewhere on the screen
Install drivers. I believe one to be somewhere in an older rooting thread maybe, also yes, easiest way for me is pull battery, put back in, while holding space+u, plug usb in. If u have cwm flashed via odin u should boot up and abd will reconize and u can mount everything there.
What exactly u trying to do?
Sent from my SPH-M580BST using Tapatalk 2
