Dead Screen. Need Keyboard sequence for USB Debugging.
jants13
4
Can someone please give me the keyboard sequence for turning on USB Debugging on a Stratosphere with a stock ROM and launcher and all? My wife dropped her phone and now the screen is dead. The touchscreen seems sort of working in places, but I can't see anything. Need to turn on USB Debugging to be able to get her contacts off of it. I see the keyboard has a menu button and arrow keys and whatnot, and if needed, I could probably click on the left bottom (or is it right?) corner of the screen to get into the menu..
I just need the steps.. like click down 5 times. Click right. Click down 4 times. Etc... I'm hoping there's a way...
Thanks,
JR
I'll answer my own question. Managed to take screenshots of steps onto SD card...
Make sure USB Cable is not connected..
Hardware Menu Button on keyboard
5 clicks right (Add, Wallpaper, Search, Notifications, Edit, SETTINGS)
enter (to go into SETTINGS)
6 clicks down (Wireless, Call, Sound, Display, Power, Location, APPLICATIONS)
enter (to go into APPLICATIONS)
6 clicks down (Unknown, Quick, Manage, Running, Memory, Battery, DEVELOPMENT)
enter (to go into DEVELOPMENT)
0 clicks up (USB DEBUGGING, Allow Mock Locations)
enter (to check USB DEBUGGING)
left (Left to go onto OK)
enter (enter to click OK)
That's it. USB Debugging is now enabled.
Enjoy.
- JR
mekonnen Ayele
