1. rvmeush's Avatar
    I recently purchased a Stratosphere II for my son. When I powered the phone on it began to take me through the activation process. I wanted to play with the phone a bit before activation so I used a technique to bypass the activation.
    In the process of playing with the phone I loaded a number of apps and some music onto a microsd card that I installed.
    I am at the point where I would like to activate the phone but I don't want to lose all the changes that I made. The only technique I have seen for activation involves doing a factory reset - which seems like it wipes the phone clean.
    Is there some technique to get back to the activation wizard without having to lose all the changes that I made?
    Thanks.
    09-07-2018 09:13 PM
  1. Replies: 2
    Last Post: 01-01-2019, 02:34 PM
  2. Has anyone ported or is anyone going to port the launchers from LG, HTC, Samsung, etc.?
    By Android Central Question in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 09-08-2018, 08:25 AM
  3. Do i have to activate a prepaid phone with a sim card to use for wifi only?
    Last Post: 09-08-2018, 02:26 AM
  4. How do you install APKs on Honda Odyssey 2019 Elite
    Last Post: 09-08-2018, 01:53 AM
  5. How can i restore deleted scribble notes
    Last Post: 09-07-2018, 07:54 PM
