1. AaronTV's Avatar
    I seem to recall reading something about this issue a while back but couldn't find it when I searched just now. Perhaps one of you can help.
    Anyway, I picked up my tablet this morning to find the battery had died. This surprised me because it had around fifty percent at least when I went to bed. After I booted up I checked battery history and found the following. Doesn't seem good...
    Posted via the Android Central App (Shield Tablet)
    03-04-2015 11:44 AM
  2. Rukbat's Avatar
    That's called "drop off the cliff", and it means the battery grew a dendrite (Lithium Battery Dendrite links for more than you want to know). The only "fix" is a new battery. You might try to copy some of the articles and convince the seller that it's a manufacturing defect covered under the warranty (it wasn't your decision to use lithium battery, it was the manufacturer's), but that's like rolling water uphill.
    Iman Mahmoodi and AaronTV like this.
    03-04-2015 12:36 PM
  3. AaronTV's Avatar
    Thanks. Do you happen to know how I should expect this to behave in the meantime? Will it drop off again like clockwork? Or is this just going to slowly get worse?
    Edit: It hasn't happened again in the past several days.
    03-04-2015 08:21 PM
  4. AaronTV's Avatar
    It occurred again last night. Nvidia is replacing the tablet under warranty. I'd be content to just mail it in for a battery replacement but I guess it must be easier for them to just replace the tablet.
    Billy95Tech likes this.
    03-18-2015 03:12 PM
  5. Paul150's Avatar
    I would be happy with the full device replacement. Sure they could crack it open, replace the battery but this way they are eliminating the problem completely with a full replacement.
    03-19-2015 05:58 PM
  6. AaronTV's Avatar
    Nvidia sent a brand new tablet via overnight shipping and included the return label for my previous tablet in the box. This whole process was taken care of with no cost to me. That is exceptional customer service. I'm impressed.
    Paul627g likes this.
    03-27-2015 09:11 PM
  7. Paul627g's Avatar
    You can't even think of complaining about service like that. I wish more OEM's would treat their customers like this.
    AaronTV likes this.
    03-30-2015 12:58 PM
  1. Replies: 4
    Last Post: 06-03-2015, 12:20 PM
  2. Replies: 37
    Last Post: 04-18-2015, 09:18 AM
  3. Replies: 9
    Last Post: 03-06-2015, 08:46 AM
  4. How do I install the Wear app on a phone running 4.4.2?
    Last Post: 03-04-2015, 11:00 AM
  5. Replies: 0
    Last Post: 03-04-2015, 10:50 AM
