Last week I was playing Fallout Shelter on my fully charged Shield LTE tablet. When I stopped playing, my battery was down to 30%, which was reasonable given how long I'd been playing.
I when I plugged it in to charge, it never went above 30%, and the charging LED next to the charging port kept flashing orange and green. I've tried charging it with the power on and off with no luck. A factory reset didn't help either.
It also seems that I can use the tablet while it's charging without causing the percentage to drop.
Is the battery borked or is there something else I could try to correct this?
