Tap on the hamburger icon top left and there should be a login / account option in that menu. Things are a bit different depending on what you're using to access the forums.
Does this site only work for some browsers? I'm using internet explorer 11 and each time I click on the Login option from the menu on the left, for some reason I'm taken to the banner behind the login option.
