Galaxy Note 10 Deal: BOGO at Verizon!
08-26-2016 07:36 PM
32 12
tools
  1. Shamshi-Adad's Avatar
    I created my user account on Windows Central, but its valid here too.
    I can DELETE a stupid post I've made at Windows Central quickly so I don't embarrass myself. but I can't here in Android Central. I can't DELETE a post here at all.
    Can I get help with that please?
    Peace. Alan
    08-26-2016 04:04 PM
  2. Javier P's Avatar
    Hello Alan! The delete option is only available on desktop site. If you prefer you can report your own post, include an explanation and a Moderator will delete it.
    08-26-2016 04:19 PM
  3. Shamshi-Adad's Avatar
    I don't understand. I'm always on my Windows 10 laptop using IE11, so I don't follow you. And your advice wouldn't work quick enough to spare me the embarrassment of others having read the dumb post already.
    But, Peace. Alan
    08-26-2016 04:26 PM
  4. Kelly Kearns's Avatar
    But, Peace. Alan
    Go into edit your post and there is an option to delete there.
    Javier P and Laura Knotek like this.
    08-26-2016 04:29 PM
  5. Javier P's Avatar
    But, Peace. Alan
    Do as Kelly Kearns said. Click on edit and then delete.
    Laura Knotek likes this.
    08-26-2016 04:31 PM
  6. Laura Knotek's Avatar
    If you are the original poster and it's the first post of a new thread, then you can't delete it. You'll need to report it so the mods can delete it.
    Javier P likes this.
    08-26-2016 04:49 PM
  7. Shamshi-Adad's Avatar
    Not for me there's not. But the "EDIT" procedure at the Windows Central forums is the same as here and I DO have an option to DELETE the post there at any of their forums. But the option TO DELETE isn't here for me when I select EDIT.
    I bet If I create a new account on THIS side it'll work. It HAS to have something to do with my account being created on the other side.
    Peace. Alan
    08-26-2016 04:50 PM
  8. Kelly Kearns's Avatar
    Peace. Alan
    See what Laura said above? Is your post you want to delete a post that created a thread?
    08-26-2016 05:08 PM
  9. Shamshi-Adad's Avatar
    It hasn't been so far. It's always been a reply.
    Y'all sound like your getting a little upset with me, but I'm tellin you there's no DELETE option after I select EDIT.
    Peace.Alan
    08-26-2016 05:16 PM
  10. Shamshi-Adad's Avatar
    Understood.
    08-26-2016 05:20 PM
  11. Javier P's Avatar
    Peace.Alan
    No, don't worry, we are not just trying to help you out. If you can't find that option your best choice is editing your post to keep it as blank as possible and report it, so a moderator will delete for you.
    Shamshi-Adad likes this.
    08-26-2016 05:24 PM
  12. Kelly Kearns's Avatar
    If I remember correctly and I'm not at my computer right now, on the desktop there is a box to check that says "delete".
    08-26-2016 05:27 PM
  13. Shamshi-Adad's Avatar
    Thank you. That's what I do lol. I delete everything I wrote but leave the quote. I guess that has mystified a couple folks
    Peace. Alan
    08-26-2016 05:27 PM
  14. Almeuit's Avatar
    Can you post a screenshot of what you see when you edit?
    It's supposed to be there for you to remove posts. The only time it isn't is if you're trying to delete the first post (as if you created a thread). That a mod has to delete.
    08-26-2016 05:31 PM
  15. Shamshi-Adad's Avatar
    I know what you mean. Its there when I edit a post at WindowsCentral, but not here.
    Folks its one of 2 things
    Either Android Central sees me coming from a Mobile Hot Spot on my phone and takes me for a mobile device but Windows Central doesn't.
    or
    All permissions don't transfer over at AC with me because my account is a WC account (basically).
    Peace Alan
    08-26-2016 05:32 PM
  16. Shamshi-Adad's Avatar
    08-26-2016 05:36 PM
  17. Kelly Kearns's Avatar
    Still from memory here.. If you click "go advanced" on the right, do you see delete then?
    08-26-2016 05:39 PM
  18. Shamshi-Adad's Avatar
    Nope. Been there and its structured the same as WC but there's no DELETE option.
    Peace. Alan
    08-26-2016 05:44 PM
  19. Shamshi-Adad's Avatar
    Well folks, I've received a PM from one of the participants telling me to just live with it. Something is broke, but.......
    Sincerely, Thank y'all for taking so much time on this.
    Tomorrow I'm gonna take this same laptop to McDonalds and use their wifi. THAT should proove whether my mobile Hot Spot is making me look mobile or not. That's the last thing I can do. THEN I'll live with it if that's the only option.
    Thanks again to all.
    Peace. Alan
    08-26-2016 06:01 PM
  20. Almeuit's Avatar
    Peace. Alan
    Ah I see the issue. Click on "Go Advanced" from the edit button. After that you can see the delete post option .
    08-26-2016 06:06 PM
  21. Almeuit's Avatar
    Addendum to my post above. I looked into your account permissions and noticed something you don't have the most do (and this may be the issue). Let me reach out to people who have more clicky powers than I do ^_^.
    Laura Knotek and Shamshi-Adad like this.
    08-26-2016 06:12 PM
  22. Almeuit's Avatar
    Peace. Alan
    Okay Alan -- Try now! It has been changed. Go into the "Go Advanced" area and you should see it .
    08-26-2016 06:14 PM
  23. Shamshi-Adad's Avatar
    BINGO !!!!! Happy Dog here.
    Peace.Alan
    08-26-2016 06:16 PM
  24. Kelly Kearns's Avatar
    Good deal! Even working from memory that sounded odd it wasn't there for you.
    08-26-2016 06:17 PM
  25. Almeuit's Avatar
    Peace.Alan
    Yay! Glad we got that resolved. Sorry for all the headache! ^_^.
    08-26-2016 06:17 PM
32 12
  1. How do I send a custom GIF????
    By trunge19 in forum Samsung Galaxy Note 7
    Last Post: 08-29-2016, 06:28 PM
  2. Replies: 1
    Last Post: 08-26-2016, 04:15 PM
