1. Jazzamuffin's Avatar
    I was hoping that would go away but it's back.
    lsmith9523 likes this.
    04-26-2017 03:52 PM
  2. Javier P's Avatar
    Which app is giving you problems? Usually clearing the cache for the app and removing it from recent apps it's enough to fix this issue. Have you already tried it?
    04-26-2017 04:01 PM
  3. Climb14er's Avatar
    Even with replacement Note 5, software all running smoothly, no social media, no other issues...
    The dreaded spinning wheel has returned! Don't understand it, this forum is the only place it's happening.
    04-29-2017 12:08 PM
  4. Mr Mendelli's Avatar
    I have found that sometimes un-installing, then re-installing fixes this. I've had to do this twice so far. I think the issue may be if the app sometimes doesn't sucessfully update or retrieve server information, and corrupts something in the data folder. I believe this to be the culperate, because on the two instances I had the issue, the prior app exits for both occourances were not clean, potentially causing data loss and/or corruption.
    05-06-2017 07:26 AM
  1. Replies: 23
    Last Post: 04-29-2017, 01:07 PM
  2. Why is it that when you try to log in.
    By cardboard60 in forum Site Feedback & Help
    Last Post: 04-27-2017, 12:17 PM
  3. Is this the mother of all flaws for s7e?
    By kupostic in forum Samsung Galaxy S7 edge
    Last Post: 04-26-2017, 04:31 PM
  4. Why is it that when you try to log in.
    By cardboard60 in forum Ask a Question
    Last Post: 04-26-2017, 11:28 AM
  5. When trying to make a call phone says mute & add call
    Last Post: 04-26-2017, 11:23 AM
