There seems to be some agreement about this.
Currently you have the S10e split off into it's own subforum and the S10 and S10+ together (for some reason).
The phone line is more than 99% the same across the S10's. They really are that similar.
I asked about this elsewhere (https://forums.androidcentral.com/showthread.php?t=964829&p=6566567&viewfull=1#post6566567), and one person pointed out that even though they have a 10e, they ask questions in the S10/S10+ forum because of the higher traffic.
I also notice that I have to check both forums for questions I have about my S10+. Yes, I could search, but searching the entire site is the only other option to checking them independently.
As an example, it was in the S10e forum that the good news showed up about wifi calling working on the unlocked S10 line on Verizon. That would have to be in both forums.
If you wish for the S10-5G to be separate because of 5G, I would still think it's a mistake, but at least pull the 10e into the 10/10+.
