A Android Central Question Feb 23, 2020 #1 Since a feature of the Google Pixel 3a phones is the "Active Edge" function, the review of phone cases should address whether they are flexible enough for it to work.
mustang7757 Admin Moderator Moderator Feb 6, 2017 98,408 14,693 113 Feb 23, 2020 #2 Some case might make it harder to use the squeeze function , so consider that when choosing one . I'll leave a link to register so you can communicate here , as a guest account you can't. https://forums.androidcentral.com/showthread.php?t=409154
