    My background and needs: I am using classic watches for years like Tissot and replicas of IWC and Panerai which are my favorite brands. I am a bit tired of replicas quality that are like lottery, lately I had a broken crown with a brand new one.
    So I am searching for a smart watch not really for fitness like many people do but for the look and quality of faces.
    2 models came in my budget and are pretty sexy: the Huawei GT2 and the Samsung Active 2
    Which model do you recommend me?
    Is there a real life difference between 1.39 and 1.4'' for an astigmatic dude like me? I don't want to put my near sight glasses every time I want to check the time
    I came to this comparison after some research but I still can't decide:
    GT2:
    +Cheaper and more available in my country
    +More classic look
    +Higher resolution screen
    +Awesome battery life
    - Limited apps
    -Limited faces
    -No animated faces?
    Active 2:
    +Cool design
    +Cool scrolling frame
    +Can add apps though I guess there aren't a big choice
    +Better OS/ menus
    +big choice of faces with animations and even sound
    -Weaker battery (2 days max)
    -More expensive
    -Difficult to find in my country due to the economical crisis (Lebanon)
    -Paint! Unless I pay even more for stainless, the aluminum ones are prone to scratches and this is a big negative for me
    01-11-2020 07:13 AM
  2. Macdtek's Avatar
    I had a Samsung wear watch last year. Sorry to say but I found the real life battery life was dreadful. A day at most. As a pebble user I was used to 5 plus days. The screen was slow to respond and I personally found the whole experience expensive and a real let down.
    I cant say about the GT2 but do a little research into something like the Amazfit range (check AliExpress) I think they're the same company or a sub brand. Also use the android system.
    Hope this helps
    04-16-2020 05:27 AM
  1. No data connection after update to Android 10
    Last Post: 01-12-2020, 04:45 AM
  2. Replies: 10
    Last Post: 01-11-2020, 07:39 PM
  3. Replies: 2
    Last Post: 01-11-2020, 08:37 AM
  4. Replies: 2
    Last Post: 01-11-2020, 12:51 AM
  5. How to turn off accessibility icon?
    Last Post: 01-11-2020, 12:50 AM
