1. Ayush Mangla's Avatar
    My note 3 neo overheats unusually high when on charging even the phone is switched off.
    The original charger also overheats. The upper screen heats up the highest and then the upper backside. While gaming and using mobile networks also i face same problem. Sometime the phone remains hot while not in use even. I visited service centre and after checking for 4 to 5 hrs they told me it's normal but i don't think so. I also faced problem of screen flickering and phone hanging while using camera due to overheating. Is there any solution for this problem?
    05-02-2015 12:20 PM
  2. Rukbat's Avatar
    Bring it back to them and ask them, if it's normal, to give you a written warranty extension in the event that Samsung determines that it's not normal, because overheating is not normal for any computer. (Or they can fix or replace it id they prefer.) If they won't, contact Samsung.
    The "solution" is probably a new motherboard, because they don't usually repair deeper than the board level these days.
    05-02-2015 01:30 PM
  1. Galaxy Note 10.1 n8013
    By Aimperial in forum Samsung Galaxy Note 10.1
    Last Post: 07-10-2015, 08:26 AM
  2. Fast charge spoils me
    By grimister in forum Samsung Galaxy Note 4
    Last Post: 05-03-2015, 11:40 PM
  3. 2500 mah extended battery with Neo hybrid spigen case
    By limitbreak09 in forum Samsung Galaxy Alpha
    Last Post: 05-03-2015, 08:51 AM
  4. Why are my Google Calendars not syncing to my Samsung Note 3?
    Last Post: 05-02-2015, 01:35 PM
  5. Replies: 1
    Last Post: 05-02-2015, 12:13 PM
