Low-code automation platforms allow the user to automate processes in the application with some or little coding knowledge. Normally, the most used components are built-in through visual modules so that users can make use of them easily and quickly. However, coding knowledge is necessary when performing complex or specific interactions.
No-code automation platforms allow both technical and non-technical users to automate processes through graphical user interfaces instead of traditional computer programming. This user interface usually involves drag and drop boxes that imitate a user's interactions with a computer.
Is it Correct
Is it Correct
