1. AC Question's Avatar
    I have Sony Xperia M4 aqua and I was wandering if there is a way to choose which volume to adjust without having to go to the settings.
    When I press the increase button while the music player is open for example, I can't access the notification volume without going to settings, I find it very annoying and I found on different phones a screen which enables the user to change between the different volume settings by increasing or decreasing the volume but I am not sure if that's only available on android 6
    Thank you.
    02-26-2016 10:23 AM
  1. Replies: 20
    Last Post: 03-19-2017, 08:33 AM
  2. Read this before upgrading to Marshmallow, things that you should know.
    By Toltepeceno Delsur in forum Android 6.0 Marshmallow
    Last Post: 06-28-2016, 07:06 PM
  3. Why is my keyboard small and move able?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 02-26-2016, 12:01 PM
  4. How to I go from Marshmallow back to Lollipop?
    By AC Question in forum Legacy Android & Other OS's
    Last Post: 02-26-2016, 10:23 AM
  5. Replies: 0
    Last Post: 02-26-2016, 10:15 AM
