1. northernpipeman's Avatar
    I'd like to be able to watch Netflix on a TV using my phone.
    I have a USB-C to HDMI adaptor that i used on a Lumia 950 to connect to a TV. however, it doesnt seem to work with the X Compact. Do i need a different adaptor, or is a there a setting / app that i could use?
    I know that Chromecast is only £20, but i thought it may be easier to use what i already have.
    11-30-2017 05:07 AM
  2. Rukbat's Avatar
    Most phones do DLNA through the USB connector, The Xperia X Compact is listed as one that does, so it should work. If it doesn't, it may need a special adapter (Samsung changed pins on their microUSB connectors all the time, but I never heard of Sony doing that) or there may be something wrong with the phone. (There's no setting, it's hardware.)
    But a Chromecast, and Google Home, should work with no problem. (And it's trivial to use once you set it up - just run the app, connect to the Chromecast you prefer [it assumes that you have more than one even if you don't] and your phone screen is now on your TV screen.)
    05-06-2018 02:51 PM
  1. Replies: 2
    Last Post: 12-01-2017, 02:47 AM
  2. Galaxy S6 - Unable to Add Music
    By Me-Hostage in forum Samsung Galaxy S6
    Last Post: 12-01-2017, 01:39 AM
  3. How can I change the default gallery app, on Nougat (moto g5s plus)
    Last Post: 11-30-2017, 09:40 PM
  4. How to recovery “MEMO” file without android OS?
    Last Post: 11-30-2017, 06:12 PM
  5. Reading the selection in Tablet using adb commands
    Last Post: 11-30-2017, 03:57 AM
