1. JobiWan144's Avatar
    I use a Sony Xperia X Compact, and in the past, I've had it set up so that plugging it in to charge at night doesn't make any sound. However, that is no longer the case, and I haven't found a way to fix it. I suspect that it changed with the Android 8 update, and I can't find the setting in either Xperia Assist or the Sound settings. Can someone direct me where to go?
    09-09-2018 03:59 AM
  2. Rukbat's Avatar
    I assume that you mean turn off all sound when the charger is plugged in, not something like Do Not Disturb (which you should find in Settings - use the search bar).
    You could use Tasker, but it's not free (although I've found it to be worth the price). IFTTT is free, it's similar, but I don't know if it can control the sound or detect the charger.
    09-09-2018 11:29 AM
  3. JobiWan144's Avatar
    No, I'm talking about the ding it makes when you plug it in. Here's how to do it in Marshmallow, but I can't find that setting anymore in Oreo.
    09-09-2018 02:03 PM
  1. Do i get the galaxy skin in fortnite if I buy the note 9 now
    By Android Central Question in forum Samsung Galaxy Note 9
    Last Post: 09-09-2018, 10:49 AM
  2. Sound stops at lock screen S8
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 09-09-2018, 03:40 AM
  3. The calculator app that can draw over other apps. I need help.
    By BabyGirlCarter73 in forum Ask a Question
    Last Post: 09-09-2018, 02:41 AM
  4. My phone reset but when i put my email in it wont let me wat to do
    Last Post: 09-09-2018, 02:39 AM
  5. The calculator app that can draw over other apps. I need help.
    Last Post: 09-09-2018, 01:49 AM
