1. BSODX's Avatar
    So, a few weeks ago, I started getting the notification "USB supplying power to attached device" while nothing is connected. When I plug the charger in, nothing happens until I switch the mode to charge device, it takes about 15-20 seconds then starts charging up. Worse is it also keeps this way when it's off. When it goes out of battery, it doesn't charge and only way to charge it up is to boot the phone plugged, and switch to charge device mode with that %1 charge phone gets.
    I checked the port (though the angle is tricky I might not have seen it) , there isn't anything out of ordinary, did a lint cleanup however it doesn't seem to go away. I'm ordering isopropyl alcohol to see if cleaning the port with it works. Any recommendations?
    Attached Thumbnails XA1 Plus "supplying power" to nothing?-_20200130_020440.jpg
    02-02-2020 07:58 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does it happen in Safe Mode as well? https://www.hardreset.info/devices/s...221/safe-mode/
    02-02-2020 11:50 AM
  3. djeire84's Avatar
    So sorry your having issues with your mobile.
    Have you tried restarting the phone with the USB charger cable plugged out?
    Have you tried hard resetting your phone?
    *Note backup your phone before hard reset*
    Please let us know how you get on.
    Éire
    BSODX likes this.
    03-06-2020 04:17 PM
  4. BSODX's Avatar
    I have tried restarting with/without cable and safe mode. Doesn't go away that way. However in some magical way, it got fixed as it came. It disappeared. Now the phone charges once it's plugged in. Sorry for the guy who'll come here years later looking for an answer as I don't know how.
    djeire84 likes this.
    03-09-2020 12:09 PM
  5. djeire84's Avatar
    Wow that's amazing news. Did you update the phone at all? It may have been an OTA update or and update through Google play that could've fixed it.
    Im delighted for you. Happy times.
    Éire 💖
    03-10-2020 05:45 PM
  6. BSODX's Avatar
    No, not any updates I authorized to install as far as I know. There hasn't been updates for a long time.
    03-14-2020 08:45 AM
  1. Flashlight blinks when I tap to turn it on, what do I do?
    Last Post: 02-02-2020, 06:41 PM
  2. unable to log in android central
    By Android Central Question in forum Site Feedback & Help
    Last Post: 02-02-2020, 04:43 PM
  3. how do i manually update google glass to final update
    By Android Central Question in forum Google Glass
    Last Post: 02-02-2020, 09:21 AM
  4. how do i manually update google glass to final update
    Last Post: 02-02-2020, 04:54 AM
  5. Transferring iPhone Data to Pixel 4 - AFTER Pixel has been set up.
    By lattemaker in forum Google Pixel 4 & Pixel 4 XL
    Last Post: 02-01-2020, 07:01 PM
