1. Vertego's Avatar
    ...are not working, apart from battery/charging.
    As I understand it, the notification LED is supposed to light up for various other events. Not happening. All relevant settings are enabled.
    Anyone got any clues/tips?
    11-11-2017 04:14 PM
  2. Stanley Kubrick's Avatar
    It is hard to find...not intuitive...but here is what you need to do.
    Let's pick something...how about messages.
    GO to Settings > Apps & notifications > App info > Messages > Notifications > Tap on the actual words themselves "Default Make sound" and another window will open up...notice as you scroll down the toggle to "Always pulse notification light"???? Make sure that is also turned on.
    Yes, it is hidden and I am not sure why it is like this but you will have to do the same thing for any and all apps that you want to activate the notification LED.
    Of course you need to have the default notification LED turned on for all apps...Settings > Apps & notifications > Configure notifications > toggle on Notification light.
    Just remember to tap on the actual words themselves once you are deeper into the individual app settings as listed above for messages. Be aware that some apps have more than one set of words to tap on with an LED toggle in both newly opened windows.
    matthewkuhl likes this.
    11-23-2017 02:47 PM
  3. Vertego's Avatar
    Thanks for that (& apologies for not responding sooner)
    12-31-2017 10:39 AM
  1. Flashing lights around screen incoming call notification
    Last Post: 08-12-2018, 11:56 AM
  2. Notifications for Samsung Reminders app not showing
    By neo999 in forum Samsung Gear S3
    Last Post: 04-22-2018, 09:45 AM
  3. Old alerts occuring in notification bar of Samsung Galaxy Tab S
    By mo k in forum General Help and How To
    Last Post: 11-11-2017, 05:23 PM
  4. What is a cursive L a notification for?
    Last Post: 11-11-2017, 03:30 PM
  5. Notification on my Note 8
    By hkula in forum Samsung Galaxy Note 8
    Last Post: 11-11-2017, 09:24 AM
