1. 79adam79's Avatar
    When you hit volume up/down on my XZ1 Compact it just alters/displays the Media volume...even when you're on the homepage and there's no media playing or media player open.
    Is there a way for it to alter/display the ring/notification by default, and only alter/display media volume when media is playing?
    Thanks.
    05-19-2019 02:13 AM
  2. VidJunky's Avatar
    Have you looked for the option in the settings? My S10 has an option that must be enabled to change the controls from what you want to what you have, perhaps yours will have the opposite control setting...? You should be able to find all volume options by typing "volume" into your settings search bar.
    05-19-2019 04:15 AM
  3. 79adam79's Avatar
    Nah, no such luck. After I couldn't find anything in settings I went on the Sony support chat (avail in settings) and was told that this is a feature of the Pie 9.0 OS and can't be changed.
    05-19-2019 11:45 AM
  4. VidJunky's Avatar
    That sucks, darn Sony. Lol. There's might be an app that will open a panel with all of your volume settings. I know on my old HTC I could touch the volume button and either see just the volume I wanted to adjust or all of them, which was sometimes a pain.
    05-19-2019 08:30 PM
  1. Why has my S9 Voice Recorder app not recorded all audio
    Last Post: 07-24-2019, 07:16 AM
  2. Only Call Audio Connecting MEDIA Not CONNECTING
    By Hassam Malik1 in forum General Help and How To
    Last Post: 05-18-2019, 01:09 PM
  3. How do I add a custom photo to always on display on my Samsung S10 +?
    By NissyRat in forum Samsung Galaxy S9 & S9+
    Last Post: 05-18-2019, 11:40 AM
  4. Display turns pink when tilting the phone up and down.
    By Albert Delgado in forum OnePlus 7 & OnePlus 7 Pro
    Last Post: 05-17-2019, 06:36 PM
  5. Aspect ratio/Display size zoomed out.
    Last Post: 05-16-2019, 10:31 PM
Tags for this Thread
