Hey Google, open the garage door! $50 Garage Door Opener
  1. khyos94's Avatar
    Just noticed there's condensation on camera lens, is there anyway to get rid of it
    Posted from my Xperia Z2 or Nexus 7 2012
    10-08-2014 08:11 AM
  2. khyos94's Avatar
    Attached Thumbnails Water Condensation on Camera Lens-27929.jpg   Water Condensation on Camera Lens-27928.jpg
    10-08-2014 08:18 AM
  3. gunzkevin's Avatar
    It should naturally go away with time. As energy from your pocket and the phone heats up the water, it will evaporate. It condenses when it hits a surface with less energy (colder).
    If you don't want to wait, you can open the micro SD flap on your phone, hold it so this flap is up. Then lightly blow dry the camera area of your phone. Have it set to the lowest heat.
    Really, you could have the blow drier ten feet away and it will work, slowly, but it will work.
    Just don't have the blow drier right on your phone. In a minute or so, it should be gone. Once you are satisfied, close the flap.
    10-08-2014 02:03 PM
  4. khyos94's Avatar
    Thanks a lot dude
    10-09-2014 06:56 AM
  5. gunzkevin's Avatar
    No problem, hope everything worked out well!
    khyos94 likes this.
    10-09-2014 09:56 AM
  1. Replies: 1
    Last Post: 10-08-2014, 05:50 PM
  2. How can I download my files to my Mac Book Pro from my HTC One?
    By Katharine Widdicoombe Smithe DeGama in forum HTC One M7
    Last Post: 10-08-2014, 04:48 PM
  3. How can I clear the tabs on my Samsung Tablet 3 10.1?
    Last Post: 10-08-2014, 04:25 PM
  4. How do I create an email address list on HUDL?
    Last Post: 10-08-2014, 04:17 PM
  5. How do I make changes on my Power On Image on my mobile?
    By N kishore in forum Ask a Question
    Last Post: 10-08-2014, 05:26 AM
