1. Essam H's Avatar
    should i update my phone to lollipop or not
    i heard some people said the battery after lollipop is really bad
    what do you think ?
    xperia z2
    06-02-2015 12:16 PM
  2. Torisen1's Avatar
    I've not had any problems with the battery since lollipop, still lasts about a day and a half.
    06-03-2015 12:52 AM
  3. gunzkevin's Avatar
    Same as above for me. I like the look better too. Maybe feels a little quicker also, but not much if any.
    06-03-2015 04:02 AM
  4. adrianjacobs's Avatar
    Same for me, working fine, maybe a slightly better battery life.
    06-03-2015 11:18 AM
  5. for3nsicguy's Avatar
    I was very hesitant to upgrade my Z2 to Lollipop. I eventually made the decision to go ahead and take it on...for better or for worse. My experience with it is pretty well documented in this thread:
    http://forums.androidcentral.com/son...p-upgrade.html
    If you do upgrade, I HIGHLY recommend you do the System Repair after/as a part of the upgrade. That way you are starting with a completely clean install of Lollipop. See my comments in the above linked post for details.
    As far as battery life goes, mine is, if anything, better on Lollipop. I usually take my phone off the charger at 4:15am and put it back on the charger at 11:00pm, which is nearly 19 hours off the charger every day. My normal use runs about 3.5-4 hours of screen on time and it usually has between 50% - 55% of the battery remaining. The heaviest use day I remember was just under 7 hours of screen on time and it still had 25% of the battery remaining when I put it on the charger that night.
    With the Z2, I don't worry about battery life or if it will get me through a day. Ever. It is awesome to have an Android phone and feel like there is no way I could completely drain the battery in one day's use.
    06-10-2015 08:30 AM
  6. Naveen Prasad's Avatar
    I highly recommend you to upgrade. The battery is actually better than in kitkat. Even after 6-7 hrs of continuous usage I still end the day with 60% battery life. Lollipop is cool too with additional transitions and graphics. Try it I'm sure you'll fall in love with it.
    Sent from my D6502 using Tapatalk
    06-17-2015 06:14 AM
  1. Replies: 1
    Last Post: 06-02-2015, 02:23 PM
  2. No Update! Help
    By Ali Shad in forum Sony Xperia Z1
    Last Post: 06-02-2015, 12:28 PM
  3. Encryption gone wrong! Can I get some help please?
    By AC Question in forum Samsung Galaxy A5
    Last Post: 06-02-2015, 12:02 PM
  4. HELP with MHL 3.0 and Note Edge
    By Moises Avellan Pitty in forum Samsung Galaxy Note Edge
    Last Post: 06-02-2015, 11:50 AM
  5. ram speeds needs to be increased for Samsung GT18262
    Last Post: 06-02-2015, 10:32 AM
