1. mikeyboy80's Avatar
    Just installed lollipop and done a master reset on my new phone but noticed the battery drained seems a little fast.
    Is there anything I can do in order to stop this fast drain?
    I read somewhere that I need to remove any apps I don't use maybe?
    04-21-2015 05:00 PM
  2. Rukbat's Avatar
    Let the update "settle in" for about a week. Then see if the battery life improves.
    Try to never let the battery get below 40% before recharging.
    Removing apps that aren't actually running frees up storage space, but it has no effect on battery life. There's some data in every byte of storage - whether it's an app or random data has no effect on the battery. If you want to keep apps from running, use apps like AutoStart - No root to keep apps from running on startup and Greenify to keep apps from running on their own. (Don't Greenify apps you want running on their own - like Phone or your texting or email apps - or you'll never get phone calls, and you'll only get texts and emails when you run the apps. Timers too - they have to run on their own.)
    04-21-2015 06:05 PM
  3. GeorgiT's Avatar
    Hi - I've noticed that my battery drain is MUCH quicker since upgrading to lollipop. (I think about two weeks ago)
    Should I do a factory reset?
    I've been reading up on RAM etc after above & other posts - should I uninstall all my clean master and one tap boost apps as they might actually be making the issue worse? I had over heating cpu yesterday for first time ever.
    04-29-2015 04:25 AM
  4. maxburn's Avatar
    Sony has a section for shaming apps using a lot of battery under 4.4.4, is that still there after the lollipop update?
    04-29-2015 07:16 PM
  1. Any way to turn off LTE data on the Galaxy S6 (AT&T version)
    By ATTGS6E in forum Samsung Galaxy S6
    Last Post: 11-03-2016, 02:41 AM
  2. Battery life vs watch faces
    By scotts9219 in forum LG G Watch
    Last Post: 05-27-2015, 03:19 PM
  3. Why is my battery life draining so fast?
    Last Post: 04-22-2015, 01:06 AM
  4. Where to get a spare battery case?
    By bertsirkin in forum Samsung Galaxy Note 4
    Last Post: 04-21-2015, 05:19 PM
