i have Z3 compact (D5803).
i have used it for a long time.
After installing "D5803_2157_Concept_6.ftf" via flashtool, my z3c lost network.
i have tried tons of methods:
i have flashed "D5803_4.4.4_23.0.A.2.93_TR.ftf", and rooted.
i have flashed "D5803_23.4.A.1.264_1289-4791_R2C.ftf" and rooted.
i have repaired the firmware via Sony PC Companion 2.1
i have repaired the firmware via Xperia Companion
i have tried installing twrp, when i try to install any custom rom, i get an error like this: "this rom is for d5803, d5833 etc etc... but you phone is differen"
i have tried this: Firmware Mobile Tools: How To Remove Pattern Lock From All Sony Xperia Without Flash
i have tried this: [Guide] Unlock Z3c international band(s) | Sony Xperia Z3 Compact
So i can flash any ftf without any problem.
But i can not install anything via twrp. (although i can install twrp)
i can root roms without any problem.
But phone can not connect to network..
it always says "invalid card. emergeny calls only"
- there is no IMEI problem..
Anyne have any solution for my problem?
Thanks...
- i have attached screenshots of *#*#service#*#* and *#*#info#*#*
Thanks...
