LuvMusic
I agree with comments reporting great sound quality on the Z3.....it's awesome.
In terms of loudness, I have found the loudness to be adequate but sometime I too wish for just a little more volume. The solution for me is the PowerAmp music player. PowerAmp has a preamp gain that allows you to boost the signal and get a little more volume. Use it carefully otherwise you will distort the amp on your phone. I find that two clicks of increasing the preamp gain does the trick. Also, PowerAmp is a fantastic player, well worth the $5.00 investment. I've been using it since my OG Droid. You can try the full functioning version free for 5 days be fore you spend your cash.
