1. fredhenk's Avatar
    Anyone using Multi-Camera mode on their Z3?
    I have a Z1 & a Z3 both bought direct & unlocked from Sony. Both are running kit kat v 4.4.4. But I cannot get them to work together. My Z3 says "connecting" but never connects to the Z1. What am I doing wrong?
    12-05-2014 06:05 PM
  2. dylan-t42's Avatar
    I've a Z2 Tablet & a Z3 Compact & they would not connect until the older tablet got its 4.4.4 Kitkat update. Now it's still a bit hit & miss but does at least work.
    The way it seems best is to have both devices hooked up to a local wifi hotspot. Then get the controlling camera setup in "Multi-camera-mode", place its NFC symbol onto the one on the second device and hold it there. You will be prompted with the "Touch to beam" text on both but only tap on the one you want to use to control the pair.
    And most of the time it will then show both camera images on one screen. There's a limit to the quality & fair bit of lag, but if you press the shutter button then a photo is taken using both sensors. Video works as well, but is lower quality than normal.
    12-11-2014 05:08 PM
  1. Battery on new HTC One (M8) HK edition
    By slin9 in forum HTC One M8
    Last Post: 06-29-2015, 04:30 PM
  2. How do I change the GSM only mode saved permanently on my Samsung Galaxy S5?
    By Elbasan Shala in forum General Help and How To
    Last Post: 12-10-2014, 08:13 AM
  3. Games on Nexus 9
    By fm123 in forum Google Nexus 9
    Last Post: 12-05-2014, 02:10 PM
  4. Wifi will not connect with Lollipop on Nexus 4
    By zkl in forum Legacy Android & Other OS's
    Last Post: 12-05-2014, 12:51 PM
