1. marrkopolo's Avatar
    My Sony Xperia Z3 Camera has a moist after I used it underwater. How can I get rid of this?
    01-29-2015 01:21 AM
  2. raqball's Avatar
    You can try to put it in a bag of rice overnight and see if it pulls the moisture out.
    01-29-2015 07:48 AM
  3. rspierenburg's Avatar
    You could also try this.
    supposedly it works.
    Rob
    01-29-2015 08:12 AM
  4. raqball's Avatar
    Rob
    That would entail tearing the Z3 apart since the back glass is not *easily* removable..
    01-29-2015 08:30 AM
  5. rspierenburg's Avatar
    Right....forgot about that.
    01-29-2015 09:30 AM
  6. anon(26204)'s Avatar
    Did you get the moisture out? I think I have the same issue.
    01-30-2015 03:15 PM
  7. cfoied's Avatar
    Use a dry tissue paper works for.me
    01-30-2015 06:51 PM
  8. batonettes's Avatar
    Guys be very cautioned about the moist. There's a possibilty liquid has entered your device.
    02-08-2015 10:25 PM
  1. Replies: 2
    Last Post: 01-30-2015, 01:55 PM
  2. Replies: 1
    Last Post: 01-29-2015, 04:13 PM
  3. Sprint S5 on Boost Mobile or another MVNO
    By G6_KidGogle in forum Samsung Galaxy S5
    Last Post: 01-29-2015, 12:12 AM
  4. Why can't I change my local profile on Galaxy S5?
