1. aznxpsyko's Avatar
    Hey guys,
    I've had my Z3 for a couple of months now and it has been a great phone, but I have been experiencing this weird problem which happens occasionally. Whenever I press the home button to exit out of an app, it would sometimes lag a bit, and then it would return finally to my home screen, but with the font on all my apps looking all smeared/overstretched out. This also applies to the font in the app drawer. Sometimes the problem would correct itself if I switch back and forth between the app and home screen, but other times I would have to restart my phone. I was wondering if you guys had any input that could help me fix my problem? I am running on stock Android 4.4.4 and using Google Launcher. I also attached a screenshot
    03-12-2015 11:48 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! I've seen posts about this before, but it's usually about Samsung devices. Does it always resolve after a reboot?
    Try wiping the cache partition: https://support.t-mobile.com/docs/DOC-16654
    03-12-2015 07:04 PM
  3. aznxpsyko's Avatar
    Correct, the problem always resolves itself upon a reboot. I've never had this issue on my old Samsung phone before, but anyways, I'll follow those steps to wipe the cache and hopefully it will clear and prevent the problem from happening again in the future. Thanks B.Diddy!
    03-13-2015 05:54 PM
  4. aznxpsyko's Avatar
    Darn, problem still occurs! Does this happen to you guy's too or is it just my phone? Maybe it could be Google launcher glitching, cuz I don't think I've ever had this issue before? Hopefully Lollipop 5.0 will fix it
    03-14-2015 09:48 PM
  5. B. Diddy's Avatar
    I think the other solution was to clear the data from the launcher itself, but this means you'll have to set up the homescreen again from scratch. Go to Settings>Apps, select Google Now Launcher, and tap Clear Cache/Clear Data. When you go back to the homescreen, it will be empty, as if you were just starting out.
    03-14-2015 10:40 PM
  1. How can I prevent my screen from turning off on my Droid Turbo?
    By blues222 in forum Motorola Droid Turbo
    Last Post: 04-19-2015, 08:32 PM
  2. Select Home popup when using Recent Apps
    By Kernelly87 in forum Ask a Question
    Last Post: 03-23-2015, 02:03 PM
  3. Can I get some help wiht a touch screen issue I am having?
    By babycrockett in forum Verizon Droid Incredible
    Last Post: 03-13-2015, 07:36 AM
  4. Replies: 1
    Last Post: 03-12-2015, 07:26 PM
  5. Why can't I turn on my AT&T HTC One M7?
    By AC Question in forum HTC One M7
    Last Post: 03-12-2015, 09:52 AM
