1. Kleptolol's Avatar
    Title says it all. My z3 was completely submerged in oil and luckily it came out fine, except the oil seems to be staying in the speakers and muffling the sound. Any way I can remove the oil safely?
    09-22-2015 10:29 AM
  2. Lou P1's Avatar
    Hey this is about 3 years late but I would recommend getting some compressed air, either in a can or an air compressor and and some "Electronic Cleaner" for cars. Go to the parts store and get a can of CRC Electronic Cleaner, its easy on electronic parts and doesnt harm most plastics. Spray into you speakers and flood out most of the oil and then spray the air into the speakers without using too much pressure. 91% rubbing alcohol works also but can damage plastic. Hope this helps someone else.
    05-23-2018 10:25 PM
  1. getting messages with delay
    By android_dev1 in forum WhatsApp for Android
    Last Post: 09-22-2015, 12:26 PM
  2. Replies: 1
    Last Post: 09-22-2015, 11:50 AM
  3. How many watts speaker should I buy to add onto tablet?
    Last Post: 09-22-2015, 11:48 AM
  4. Keyboard in message app freezes
    Last Post: 09-22-2015, 10:19 AM
