1. azim06eee's Avatar
    Dear sir,
    I have a xperia Z3V. It was rooted by me. It worked fine until a major mistake. I flashed a zip file. After flashing that zip file my phone won't turn on. When I connect to wall charger only red led blinks frequently. When I connect to my laptop , red and green led blinks frequently.
    I tried to flash firmware by flash tools.But it does not go to flashmode option when I press volume down key. But when I press volume up key then it goes to fastboot mode. Also I am able to go factory mode when I press and hold power and volume down key together and I see following 4 options
    1. Continue power up
    2.Safe mode
    3.factory reset
    4.Power down
    but no option can make my z3v alive.
    I tried PCC also. but did not detect my phone.
    So would you please suggest me regarding the possible solutions.
    12-23-2016 06:46 AM
  2. sudhanshurocks's Avatar
    Dear sir,
    2.Safe mode
    3.factory reset
    4.Power down
    Hi there
    Welcome to Android Forums
    Do you have custom recovery installed ?
    Just Don't worry ,Soft brick can be handled easily ,
    Thanks
    azim06eee likes this.
    12-23-2016 06:57 AM
  3. azim06eee's Avatar
    Thanks for quick response. I tried to install custom recovery TWRP but finally PC did not detect adb devices.
    12-23-2016 07:04 AM
  4. sudhanshurocks's Avatar
    Hey
    Sometimes happens ,do one thing ,as you can enter fastboot mode ,open fastboot mode , connect your phone to pc ,open the folder where you have adb and fastboot files ) open command window there ) type fastboot devices ) and if it detects it )
    Place your twrp in same folder , and type " fastboot flash recovery " twrp.img "
    Pls take care you enter the correct name of recovery okay .
    If you face any problems in following the steps ,ask doubts without hesitation
    Follow the steps and let me know if worked
    12-23-2016 07:07 AM
  5. azim06eee's Avatar
    OK,sir I am starting from beginning though I tried it before. I failed that time and I can't remember the actual cause. Now I will show what my PC shows. Thanks for your kind cooperation.
    sudhanshurocks likes this.
    12-23-2016 07:18 AM
  6. Golfdriver97's Avatar
    Do you know what the model number is?
    12-23-2016 08:59 AM
  7. azim06eee's Avatar
    It is xperia z3v and it's model number is D6708
    12-23-2016 09:21 AM
  8. B. Diddy's Avatar
    Merged duplicate threads.
    12-23-2016 06:21 PM
  9. azim06eee's Avatar
    Hey
    Dear sir, At first my phone was unrooted with stock KitKat ROM. Then I rooted my phone with the help of D6616_rootfull zip file. Then I used Custom recovery by the help of T2U-lockeddualrecovery2.8.21-REL EASE.installer.zip. In this recovery I used windows Batch file for custom recovery.
    Now I can't do by this method.
    Now I have only fastboot option but I have no custom recovery twrp.img for my xpeia D6708. I searched Google but failed.
    For your kind information my PC gets SOMC driver when I use test point.
    Have any tips?
    12-24-2016 12:43 AM
  10. sudhanshurocks's Avatar
    Have any tips?
    Hey
    You said earlier you can enter fast boot mode on your phone ,adb works or not it's okay .
    Follow the exact steps mentioned in my earlier post did ya ?
    12-24-2016 12:45 AM
  11. azim06eee's Avatar
    Dear sir,
    Yes ,I only can enter fast boot mode. But problem is , I have no twrp.img for my device.
    So how can I install custom recovery twrp.img by fastboot mode? From where I can get twrp.img for my D6708? Also can I use other twrp.img ?
    12-24-2016 01:08 AM
  12. sudhanshurocks's Avatar
    Dear sir,
    Can u contact me somewhere else like WhatsApp ,kik ? Bcoz it's so complicated to explain here
    12-24-2016 01:12 AM
  13. Efren Rebaza's Avatar
    Hello,
    I have the same problem. do you can help me please?
    04-05-2017 09:44 PM
  1. Replies: 14
    Last Post: 05-20-2019, 10:27 AM
  2. How do I change the setup of my quick memo on my lg k3
    Last Post: 11-10-2018, 09:05 PM
  3. Replies: 2
    Last Post: 12-23-2016, 04:44 PM
  4. apphider on google play
    Last Post: 12-23-2016, 03:44 AM
  5. Replies: 0
    Last Post: 12-22-2016, 11:40 PM
