It seems the Z5 Premium might not be waterproof anymore which is a bummer.
I was really hoping for it to have the same disclaimer as the Z3:
*The Xperia Z3 is waterproof and protected against dust as long as you follow a few simple instructions: all ports and attached covers are firmly closed; you can’t take the phone deeper than 1.5m of water and for longer than 30 minutes; and the water should be fresh water. Casual use in chlorinated pools is permitted provided it’s rinsed in fresh water afterwards. No seawater and no salt water pools. Abuse and improper use of device will invalidate warranty. The phone has an Ingress Protection rating of IP65 and IP68.
But alas, no full submersion for the Z5:
**** The Xperia Z5 Premium is waterproof and protected against dust, so don’t worry if you get caught in the rain or want to wash off dirt under a tap, but remember: all ports and attached covers should be firmly closed. You should not put the device completely underwater or expose it to seawater, salt water, chlorinated water or liquids such as drinks. Abuse and improper use of device will invalidate warranty. The device has Ingress Protection rating IP65/68.
Think they'll update the disclaimer closer to launch or is it really that much less waterproof now that they have an open USB port?
