1. etexans82's Avatar
    Anyone else having this issue or know how to solve it?
    04-22-2016 03:43 PM
  2. Reggie's Avatar
    How hot? This processor in our phone runs hot. It is why Samsung used their own processor in the S6 phones. Sony used a heat sink to resolve this issue. Sometimes mine is warm but never what I would call hot.
    04-24-2016 05:47 PM
  3. etexans82's Avatar
    I can feel the heat in my pocket and my battery doesn't last as long after updating to Marshmallow. So I'm trying to figure out if these are to separate issue or along the same lines because this has only been happening after Marshmallow update. It use to get warm/hot before if I'm power using it but not just sitting idle on the table or in my pocket. I don't really see any apps running in the background that would be different after the update but it's becoming very annoying.
    04-25-2016 12:21 PM
  4. Francis Amar Singh's Avatar
    Never hot.. Warm maybe.
    04-25-2016 08:12 PM
  5. TIM Hughes1's Avatar
    Do a clean install of marshmallow using pc companion.
    04-27-2016 03:36 PM
  6. etexans82's Avatar
    Ok. I'll try that!
    04-29-2016 04:22 PM
  7. itguyjax8430's Avatar
    Did the clean install fix the issue?
    05-04-2016 07:38 AM
  8. etexans82's Avatar
    I actually just did a factory reset yesterday and seems to working fine again with no heat issues. So, we'll see if that continues.
    05-04-2016 03:38 PM
  9. AJS_2010's Avatar
    I also had this issue. Every morning after switching it on I could feel the phone quite hot in my pocket. Hot enough to make it really annoying. Did a clean install and although it was a pain in the back side reinstalling apps and restoring photos, contacts etc, it worked a treat. No more heating issues. Also the battery seems to be lasting longer. After 6 hours switched on,I was on 75% tops. After reinstalling marshmallow I'm normally around 90-95% . Best advice I ever read around here.thanks
    08-09-2016 08:03 AM
  10. Reggie's Avatar
    Great news that the reset worked
    08-10-2016 08:34 AM
  1. Replies: 3
    Last Post: 04-22-2016, 02:46 PM
  2. Headphone Jack Issues
    By L0n3N1nja in forum Samsung Galaxy S7
    Last Post: 04-22-2016, 02:35 PM
  3. Internet and Gmail not syncing after Marshmallow update
    Last Post: 04-22-2016, 02:20 PM
  4. Replies: 0
    Last Post: 04-22-2016, 12:51 PM
