1. 123Easy's Avatar
    Sony Xperia Z5 family has dual heat pipes inside. It is different from its predecessor.
    11-11-2015 10:46 PM
  2. Rukbat's Avatar
    Hardware designers put in what's needed, they wouldn't put in dual pipes for the looks. They probably want the heat dissipation to occur evenly on both sides of the phone, rather than a single larger pipe making one side of the phone hot.
    11-12-2015 12:20 AM
  3. michon_van_nimwe's Avatar
    In Any case, I'm not having Any problems with my Phone with regards to the excessive heat. Sure it gets warm once in a while but not like my Z1 did. So it steeds to be working.
    12-05-2015 03:18 PM
  4. Billy Bob Jimmy Joe's Avatar
    I bought this Z5 Compact two days ago. No excessive heat at all. I played games for a while, watch YouTube for a while, took quite a few pictures. It gets warm but never hot for me.
    Sony Xperia Z5 Compact
    12-06-2015 02:05 AM
  1. Marshmallow built in Visual Voicemail...but not for Google Voice?
    By npaladin-2000 in forum Legacy Android & Other OS's
    Last Post: 01-21-2016, 10:35 AM
  2. How are the T-Mobile signals in Cincinnati and NKY
    By Droidperks in forum General Carrier Discussion
    Last Post: 12-22-2015, 08:00 AM
  3. How do you get slide to unlock work?
    Last Post: 11-11-2015, 11:11 PM
  4. looking for a flagship device under 5 inches
    By yubeie in forum Ask a Question
    Last Post: 11-11-2015, 09:58 PM
