Save big + get 3 months free! Sign up for ExpressVPN today
Camera Flash Randomly Not Working
- After a restart the flash still did not work, however it did work on my flashlight widget.
Even though no one encountered this problem, I thought I'd leave the solution that worked for me in case any people are Googling to get here:
The support tech had me reset the phone by taking the battery out. That did not work.
Then they had me go to Settings, Apps, All Apps, Camera.
In the camera app section, press "Clear Data".
This fixed it.11-20-2017 05:44 PMLike 0 - my flash should flicker for awhile n randomly stopped working, any suggestions guys...im using a huawei p8 liteBalkanNoob2609 likes this.12-18-2017 01:09 PMLike 1
This fixed it.06-22-2018 02:50 PMLike 0 - After a restart the flash still did not work, however it did work on my flashlight widget.
This fixed it.12-31-2018 10:18 PMLike 0 - B. DiddySenior AmbassadorThe Application Manager is the same as Settings>Apps. Depending on the phone and OS version, you might see different categories (like User Installed, System, Disabled, All Apps), or you might just see one list. If you don't see Camera, tap Menu and look for a Show System option.01-01-2019 03:55 PMLike 0
- Forum
- Samsung Android Phones
- More Samsung Phones
- Samsung Galaxy Nexus
- Sprint Galaxy Nexus
