From reading some reviews on the qmadix unit, they only seem to include the iphone cable, and apparently there is a difference between a USB charging cable and a USB synching cable with the latter not recognizing the charger as an ac source but instead just treating it like it was plugged in to a computer. Question is, will the cables that ship with our phones be recognized as a charging cable or just a USB cable? Confusing stuff.
Hello Manny,
The issue is not with the cable. The issue is with the charger. USB cables have 4 internal wires. +5Vdc, Ground, D+, and D-.
Normally D+ and D- are used for data transmission only. However, a standard emerged called DCP, in which phone chargers that don't care about data can use the D+ and D- lines to detect compatible devices and ramp up the amperage on the +5Vdc line. Ordinarily, USB standard mandates 500mA current for USB 1 compliant devices.
What Apple does is apply a 2.4Vdc voltage to the data lines so that compatible devices will allow full charging. Because Android phones don't do this, Apple compatible chargers revert to standard USB mode and you get really slow charging.
Most Android phone chargers short the D+ and D- lines. When phones that use this method sense that lines are shorted (Won't happen with a normal PC USB port), the phone allows full charging and views itself as connected to AC. I'm pretty sure the Note 2 uses this method.
There are a few other variations on this, but that's the general principle.
Most Chargers listed as "Universal" have some type of autodetection for this. They can "sense" when an Apple product is attached and then apply the 2.4Vdc. They can also sense when a device that needs the lines shorted, and will short accordingly, to enable full charging.
You could do this buy creating a charging cable with the D+and- lines shorted, but I would be careful. If you forget and use this cable with a PC, you will probably damage your computer. (I've seen people do this.) My thought are to just by the right charger.
I know I've gone over into the techie pool, but this is how this works.
-Plaz
