These TYLT one look good. They also look like they pass the amperage test. Have any reports on these? Also luvsmobile do you work for them?
This seems to be the best place for Galaxy Note 2 car charger info on the web!
I bought this charger: Amazon.com: Satechi CA-2421STB Car Lighter USB Charger Adapter with Smart Converter for iPad 2 & 3, iPhone 4S & 5, Samsung Galaxy S II & S III, BlackBerry Playbook, HTC Flyer, Android Phones (2.1 AMP): Cell Phones & Accessories
It seemed like a good bet because it comes with an adapter that claims to correct the issue of Android devices charging at the low rate.
(I also wanted a "flush mount" plug, and the others listed here as "sure to work" seemed large.)
However, I find that my Note 2 shows "(AC)" whether I use the adapter or not on this car charger!
It seems confusing that this charger specifically says you need the adapter to make it charge at the fast rate with android devices, but the Note 2 shows "(AC)" with or without the adapter.
FYI: Just to test, I tried plugging my phone into a wall charger that says its maximum output is 500ma, and it does say "(USB)" under the battery settings with a 500ma wall charger!
I have not done any charge time measurements yet.
I got this one about 3 weeks ago. I'm very happy with it. [. . .]
New Trent Arcadia Rapiduo (1 pc), 10W 5V/2A Dual Port high-speed USB car charger w/ Free Full Speed Micro-USB Charging Cable (IMP80C/NT80C):Amazon:Cell Phones & Accessories
I got this one about 3 weeks ago. I'm very happy with it. I'm using a Galaxy S4 abs you can see the charge rate is pretty hi. I want using any apps at the time but it still charges very well when I am.
Sent from my SGH-M919 using AC Forums mobile app
Just tried the MediaBridge (ala post 91, link below). Again, it failed to charge my Asus ME301T tablet, but it did slow battery drain rate slightly. Tablet indicators showed "AC connected" (consistent with Data pins being shorted?) but battery drain was merely slowed. Called MediaBridge -- they picked right up and were very responsive, but, at the end of the day, they could provide no explanation beyond "they can't guarantee compatibility with every device"). So, it goes back as well, and I'll keep looking.
Amazon.com: Mediabridge High Output Dual USB Car Charger For Samsung S3, Galaxy Tab, Nexus (3.1 Amp): Cell Phones & Accessories
