1. Roy Vongmany's Avatar
    As stated I have tried removing the battery with no change. I can turn off smart stay; the text on the smart rotation is faded and check marked not letting me unmark it. Its draining my battery horribly HELP!!!
    03-11-2013 11:24 PM
  2. SDHarleydad's Avatar
    Something else must be wrong because smart rotation is not noticeably draining my battery... might need a hard reset.
    03-12-2013 07:55 AM
  3. Skunkape60's Avatar
    Smart rotation is most likely no the cause of your battery drain. The battery it takes is insignificant. However my ability to deselect it went away after the ma7 update. A data reset fixed it.
    03-13-2013 07:49 AM
  4. Roy Vongmany's Avatar
    I had to reset back to factory to rid of the problem My battery does last longer without it being continually on.
    03-14-2013 04:39 PM
  5. kirakiravita's Avatar
    I had the same issue and solved it without a reset. Go to Accessibility under Settings and check "Auto-rotate screen." You can then go back to Display and uncheck Smart Rotation. If you go back to Accessibility and uncheck Auto-Rotate, it will not re-check Smart Rotation. Hope this helps.
    04-05-2013 11:42 AM
  6. ssffggrr's Avatar
    Thanks allot!!! You saved me a reset on my new s4!!!
    05-04-2013 01:57 AM
  1. Screen will not turn off since the JB update on Sunday
    By gsampl4 in forum Verizon Galaxy Nexus
    Last Post: 09-27-2012, 01:38 PM
  2. Phone will not turn off while charging
    By jeffwhite10 in forum General Help and How To
    Last Post: 02-07-2012, 08:25 PM
  3. Replies: 6
    Last Post: 10-16-2011, 11:01 PM
  4. Motorola BT Keyboard Will Not Turn Off
    By gsmitchell in forum Motorola Xoom
    Last Post: 09-05-2011, 08:55 AM
  5. randomly shuts off and will not turn back on
    By bmderuosi in forum Motorola Droid
    Last Post: 11-14-2009, 07:30 AM
