Go into maps/settings/location/ disable report from this device and location reporting
Sent from my SGH-T999 using Android Central Forums
This doesn't fix it. I've tried everything. I thought I had it fixed after un installing maps delete data, cache, ect. Reboot phone open maps then reboot again then install maps again.... It fixed it for a day or two.
I've pulled the battery ect. People have done factory resets and it doesn't fix it.
It just sucks because with 4.1.1 it was fine and maps never used 30+% with my phone just sitting there overnight. Ever since 4.1.2 it's been doing it. I've looked for rouge apps. I've done everything I can do. I found out that it's Google Now that is causing this though. But I like Google Now way to much to disable it just for an hour or so more Battery life.
I just don't understand why it was fine with 4.1.1, so it has to be Google Now and map's conflicting some how.
It could be as easy as an update to Google Now. I've gone to the Play Store and changed my reviews abs explained the issue in the review on both maps and Google Now.
More people need to do the same as well as reporting the app and explain the issue in that as well.
Maybe it can be fixed that easy. That's Edgar I'm hoping anyway. I guess we'll just have to see what they do.
Sent from my SGH-T889 using Tapatalk 2
