1. li2327's Avatar
    Hello looking for some help. My battery percentage on my phone won't move. Even if its fully charged unless I pull the battery. Then it goes back to not moving again. Ive done several factory resets and I still have the problem. My phone is stock. Is there anything I can do before taking it in to Sprint?
    Sent from my SPH-L900 using Tapatalk 2
    04-14-2013 01:35 AM
  2. soulstlr's Avatar
    sorry for your dilemma...
    have you perhaps installed one of the many battery apps in the market to see perchance it registers the correct percentage as a way of narrowing down where the problem is?
    do the contacts that the battery connects to appear corroded?
    other than the percentage not registering does the device seem to be normally operational?
    just thinking out loud...
    04-14-2013 10:34 AM
  3. li2327's Avatar
    Everthing seems to be working fine other than me not getting my gmail notifications. Its not rebooting or anything like that.
    04-14-2013 10:54 AM
  4. soulstlr's Avatar
    have you tried a battery app?
    04-14-2013 10:58 AM
  5. li2327's Avatar
    What app should I try
    Sent from my Samsung Galaxy Note 2 using Tapatalk 2
    04-14-2013 01:23 PM
  6. soulstlr's Avatar
    well, i have used a few different ones but seem to have settled on:
    https://play.google.com/store/apps/d...ch.battery.pro
    but there is also a free version you might want to try:
    https://play.google.com/store/apps/d...RlcnkuZnJlZSJd
    very detailed and extremely easy to use.
    at the very least you would be able to narrow the search for your ongoing problem.
    04-14-2013 01:55 PM
  7. li2327's Avatar
    I took it to the Sprint store since I have insurance. Its a issue with the hardware. They ordered me a replacement. It will be here Thursday.
    soulstlr likes this.
    04-14-2013 05:23 PM
  8. li2327's Avatar
    Got my replacement phone last night. They gave me white so I woulndnt have to wait. I'm liking the white.
    04-16-2013 01:36 PM
  1. huawei u8652 Fusion not showing battery percentage?
    By John_Mart in forum Android Apps
    Last Post: 12-28-2012, 09:30 PM
  2. Replies: 12
    Last Post: 08-21-2011, 08:29 PM
  3. battery level not changing
    By zachnelson in forum Verizon HTC Thunderbolt
    Last Post: 04-13-2011, 07:14 AM
  4. Battery life not lasting? Your fix is in here
    By HardHitter#AC in forum Verizon Droid Incredible
    Last Post: 06-07-2010, 11:08 AM
  5. App For Battery Percentage to replace in notification bar?
    By surfacinglove in forum Verizon Droid Incredible
    Last Post: 05-11-2010, 10:46 AM
