1. kanesmith41's Avatar
    Hi, I'm trying to figure out how to get the most battery life on my gn2 and the proper settings to achieve this. I've tried a application called Deep sleep battery saver, but I couldn't see a big difference or I didn't have it set up properly. Recently I've gotten a little over 36 hrs on a charge and I thought that was pretty good. I'm sometimes a heavy to light user. Any suggestions would be appreciated.
    GN2
    09-02-2013 09:25 AM
  2. msndrstood's Avatar
    36 hours on a stock battery is pretty good! Can you post screen shots of your battery stats and on screen time? The on screen time is really the key. You can get many hours of stand by with little on screen time.
    Sent via Note II
    09-02-2013 10:24 AM
  3. kanesmith41's Avatar
    Ok, let me see how to do it, I'm still new here.
    Sprint GN2
    09-02-2013 10:26 AM
  4. kanesmith41's Avatar
    Ok, I'm lost. How do you post a photo?
    Sprint GN2
    09-02-2013 10:29 AM
  5. msndrstood's Avatar
    Do you know how to do the screen shot of the battery stats in settings?
    And are you on your phone or desktop and which app are you using to view AC? I'm using the Tapatalk 2 app.
    Sent via Note II
    09-02-2013 10:54 AM
  6. kanesmith41's Avatar
    This is my screen shot.
    09-02-2013 10:54 AM
  7. kanesmith41's Avatar
    I was using my phone to do this. My computer crashed. Hope this photo works.
    Sprint GN2
    09-02-2013 10:56 AM
  8. msndrstood's Avatar
    Like this
    Sent via Note II
    09-02-2013 10:56 AM
  9. kanesmith41's Avatar
    Sorry, I didn't take a screen shot of the display.
    Sprint GN2
    09-02-2013 10:58 AM
  10. kanesmith41's Avatar
    I'll display the proper information next time. What settings would you suggest I use. I'm currently using a application called deep sleep battery saver so my sync settings are still on and my screen display is turned all the way down.
    Sprint GN2
    09-02-2013 11:04 AM
  11. msndrstood's Avatar
    I toggle my stuff manually. I used Battery Guru and a few others and found that my Wi-Fi would get stuck off and I would have to reboot, do now I have everything off until I need it. Wi-Fi, 3G, Bluetooth, GPS. I do use location services and Google now. I am battery paranoid and have extended batteries for all my phones. I'm on Wi-Fi 85% of the time, my 3G signal is ok, but I'm in the boonies so I can burn through battery pretty quick on 3G.
    What are your settings?
    Sent via Note II
    09-02-2013 12:15 PM
  12. msndrstood's Avatar
    I toggle my stuff manually. I used Battery Guru and a few others and found that my Wi-Fi would get stuck off and I would have to reboot, so now I have everything off until I need it. Wi-Fi, 3G, Bluetooth, GPS.
    Sent via Note II
    Oops double TT post again.
    Update: I meant Juice Defender, I do have Battery Guru too, but Juice Defender caused the Wi-Fi issue. Sorry.
    Sent via Note II
    09-02-2013 12:15 PM
  13. kanesmith41's Avatar
    Didn't think about the Google settings. I'll turn that off. Everything is pretty much off. I use my sprint airave when I'm home. But like I was saying, I'm using a application called deep sleep battery saver at the moment so when my screen turns off, it's supposed to shut everything down until I unlock my screen.
    Sprint GN2
    09-02-2013 01:42 PM
  1. Cannot power on my bionic, white notification light
    By David Peradze in forum Droid Bionic
    Last Post: 09-16-2013, 10:17 AM
  2. Replies: 11
    Last Post: 09-06-2013, 10:06 PM
  3. wow 5 yrs on a ihone 3gs,
    By rs500888 in forum New to the Forums? Introduce Yourself Here!
    Last Post: 09-02-2013, 01:48 PM
  4. message alert on active
    By lawdawg210 in forum Samsung Galaxy S4 Active
    Last Post: 09-02-2013, 05:05 AM
  5. help my htc evo wont turn on
    By droid1998 in forum HTC EVO Design 4G
    Last Post: 09-02-2013, 03:19 AM
