1. matthewmpease's Avatar
    hi, so im an *****. and ill start from the beginning.
    I recently rooted my sprint note 2, and attempted to flash ParanoidAndroid on it. which worked fine, but I had to download the google apps thing for the playstore to work. when I did this, my keyboard wouldn't work. tried to restart it and now for some reason its stuck in a bootloop. I am using team win recovery, and messing around with it accidentally wiped my system. when I tried to boot it up It would say, "no OS installed! are you sure you want to reboot?" until I went into "install" and installed the paranoidandroid file and now when I try to reboot it just says "your device does not appear to be rooted, install supersu? whis will root your device." when I say no don't install, it bootloops back to teamwin recovery, when I swipe yes install...it does the same thing. and to top everything off, my computer recognizes my device, but wont let me open the files. PLEASE HELP ME
    09-14-2013 03:15 PM
  2. mmgquiet's Avatar
    Follow the instructions in this video. Good luck.
    09-14-2013 07:35 PM
  3. matthewmpease's Avatar
    thank you but nothing is working. I give up ive been at it for 2 weeks.
    09-15-2013 02:09 AM
  4. mmgquiet's Avatar
    Take it to the nearest Sprint store. They should be able to Unbrick it for you.
    09-15-2013 10:10 AM
  1. Lurker needs help! Please!
    By NattyDaddy in forum New to the Forums? Introduce Yourself Here!
    Last Post: 09-17-2013, 11:15 PM
  2. att galaxy s3 rooting help pleaseee
    By rohrbaugh26 in forum AT&T Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 09-17-2013, 06:49 AM
  3. Extreme data usage from Google services
    By djkleric in forum Google Nexus 4
    Last Post: 09-15-2013, 12:28 PM
  4. Migration help needed - (how to back up EVERYTHING)
    By TNF734 in forum General Help and How To
    Last Post: 09-14-2013, 05:49 PM
  5. Help, please: latest Google system update, what..?
    By lux aureole in forum HP Slate 7
    Last Post: 09-14-2013, 10:53 AM
