1. kanesmith41's Avatar
    Hello, just wondering if anyone had any ideas on saving battery life on note 2? I've got just about everything turned to the lowest setting and I've been using a application called deep sleep battery saver. Any suggestions would be appreciated.
    USMC97/ GN2
    12-01-2013 08:18 PM
  2. Darrel Valencia's Avatar
    Turn off wifi when not needed and off others like bluetooth nfc gestures settings etc when u dont really use it. Check auto brightness. Limit notifications on certain apps by going on its setting. Check battery on setting and see which app eat battery. im new to android and this is what i do , sorry for my bad english...
    Also i turned off data connection when i know i will not be able to plug my phone. Like for example im at 40% i turn off data. And will only turn on when i know or expect emails or message. (i normally open the app for fast fetching of data)
    Hope it helps even a little
    Sent from my SM-N9005 using Tapatalk
    12-01-2013 08:49 PM
  3. kanesmith41's Avatar
    Thanks, I appreciate it. I've got all that turned off and only use wifi when I'm at home. I just checked my phone after an hour and it used 6%. I downloaded a application to see what's killing my battery, But it's not showing anything with high usage. My do a battery pull and see what happens. I usually do that once a month.
    USMC97/ GN2
    12-01-2013 09:35 PM
  4. jocarog's Avatar
    USMC97/ GN2
    If it's rooted get Better Battery Stats to find out what's eating your battery, turn off Google Now and get Greenify to hibernate apps when sleeping (needs root access) I go 1d 5 hours with a single charge...
    Sent from my SPH-L900 using Tapatalk 4
    12-03-2013 08:06 AM
  5. kanesmith41's Avatar
    Thanks, I've been using deep sleep battery saver and I've gotten 39 hrs on one charge.
    USMC97/ GN2
    12-03-2013 11:27 AM
  1. Blue HTC one from Best Buy
    By jackwagon06 in forum Verizon HTC One
    Last Post: 01-10-2014, 04:42 PM
  2. Best Christmas Ringtone 2013 for free
    By LuckyNote in forum Wallpapers, Ringtones, and Themes
    Last Post: 12-13-2013, 05:44 AM
  3. Best ROOTED HTC One HomeScreens !
    By Don164 in forum HTC One M7
    Last Post: 12-03-2013, 02:45 PM
  4. HTC One Battery question
    By parkerd97 in forum HTC One M7
    Last Post: 12-01-2013, 05:35 PM
  5. Gsam battery and htc one.
    By purpleparrotuk in forum HTC One M7
    Last Post: 12-01-2013, 04:55 PM
