1. nikeairs23's Avatar
    Is there an app I need. The Blue and Red ones work. The Red one seems to slowly flash when I have an email waiting to be read. But that's about it. What about the 2 lights on the left of the phone. Near the cam. Do they work?
    09-25-2011 05:12 PM
  2. garrettfarnum's Avatar
    Yes, they're flash for the camera.
    09-25-2011 05:16 PM
  3. mylgt1's Avatar
    I assume your talking about the front camera, if so they're not leds but are a proximity and a light sensor!
    09-25-2011 05:36 PM
  4. nikeairs23's Avatar
    Oh, so those aren't the notification lights?
    09-25-2011 05:38 PM
  5. Samsmalls's Avatar
    If you use the auto brightness setting, you'll notice a difference in you screen by placing a thumb or finger over those sensors!
    09-25-2011 05:41 PM
  6. nikeairs23's Avatar
    in the booklet it just say LED for them. It should say sensor or something. I thought they were lights that don't work
    09-25-2011 06:00 PM
  7. JayWill's Avatar
    Yeah the user guide has a few errors. Labeling the light and proximity sensors as a LED is one of them.
    09-25-2011 10:46 PM
