How to Turn Off Your Shutter Sound In 2 Minutes
629Classic
24
see my post about changing permissions of the file
Thanks a bunch! This method worked for me as well once I changed the permissions, and everything is working fine. However, there is now a "features.xml.bak" file showing up in addition to the "features.xml" file in the system/csc directory. Also, there are files named "contents.db" and "sales_code.dat" in the same directory. I don't recall any of these files being in the directory before I made the edit. Would anyone happen to know why these additional files are now showing?
Avery1237
Did you delete the files instead of renaming them? I will try and get them to you.
Here's your files....
Why does my Samsung Galaxy S3 not have these files to begin with? I am using the SPH-L710 on Sprint. I cannot find any files named System, Audio or UI either. Help appreciated.
Skunkape60
4,460
344
I am also a Sprint user. Could you help me out? I cannot locate any files named System, Audio or UI.
Thanks.
These are folders
system / media / audio / UI
The media folder is in the system folder.
The audio folder is in the media folder.
The ui folder is in the audio folder.
The ogg files you are looking for are in the ui folder.
You must have a root explorer such as es file explorer or root explorer.
Thrillhouse617
70
5
I have those files and the modified dates are way back in the past.
Skunk- can you update the top post to make sure people are checking the permissions? May save a few pages of reading :)
Skunkape60
4,460
344
You don't need to change permissions. You are just adding .bak to the end of the file names. I will have to read back a bit too figure out what you're talking about.
Edit: I think I see what you're talking about. Edited op....
Thrillhouse617
70
5
cool, I was never able to totally defeat the sounds by doing that no matter how many resets I did. seems easier
meyerweb#CB
Banned
Sep 4, 2009
6,668
5
Skunkape, the first post now reads:
3. Under find the following line
false
without saying what line we're supposed to change. I think I found it, but just want to be sure....
timbyts
The easiest way to turn off the shutter sound is to turn down the volume BEFORE you open the camera app. Once that is done....presto...no more shutter sound. Easy as pie.
rando991
588
30
First of all you must be rooted and have a file explorer with read/write. This is very easy and is posted by freeza at xda. So I figured I would just share the information with my friends here. So if you use this please give him a thanks.
1. browse to system/csc
2. open feature.xml in a text editor. (With root explorer hold down on the file and choose open in text editor.)
false
Change the false to true. Save and exit. Reboot your phone and under camera settings just under GPS Tag you will have the option to turn it on or off.
To get this to work you must also change permissions.
Huh? "Under find the following line
false"
What there's a line called "false" or there's a line called "find the following line?"
I'm confused and there are A LOT of lines. Somebody please clarify what line we are looking for. Thanks!
rando991
588
30
Uh...no. that does NOT work. At all.
Sent from my SPH-L710 using Tapatalk 2
nameless-
5
OK... Now I have something that does work. Here's how to shut off them camera sounds. This time I verified it works before posting. :D
Scroll down until you see Shutter.ogg and Shutter_multiple.ogg. To the end of both of those file names add .bak
So it will look like this:
Shutter.ogg.bak
Shutter_multiple.ogg.bak
You will (of course) need to be rooted and have read/write enabled and restart your phone. Then those pesky shutter sounds will be gone for good.
Thanks should go to drawde40599
worked perfectly !:D
rando991
588
30
false
this works if you change step 3 to:
3. Under the line "CscFeature_Camera_ShutterSoundMenu>false</CscFeature_Camera_ShutterSoundMenu." Change "false" to "true."
LayeredLife
Just rooted my phone 2 days ago.. went to the .xml file and changed it to true (show the shutter sound option while in my native camera) and RESTARTED my phone... it works perfectly.. even turned off my focus sound too!!
I also enabled the camera while making phone calls .. (same .xml file) I was updated to android 4.1.1 when I rooted... Sprint didn't allow me to use my camera while on the phone.. dumb.
Both of these changes require a restart ...
Thanks for all the help!! :cool:
GianDChik
Okay, I have read these post multiple times trying to figure out how to root my phone to get to the Shutter sound off. I have the Sprint Samsung Galaxy S3. I downloaded Es File Explorer file Manager and followed the Youtube videos to root my phone with this app. Every time i click on Root Explorer to root my phone it tells me, "Sorry test failed this feature cannot run on your device." Is there anything else I can do to get this shutter sound turned off.
Thank you
kirk781
