1. Gleibis Leon's Avatar
    My phone is driving me crazy. My play store does not wants
    to work. I can't do any updates or downloads, what should I do?........
    10-30-2013 10:59 AM
  2. joshsparham's Avatar
    Try doing this:
    Settings
    Application Manager
    Find Google Play Store
    Click Uninstall Updates
    Restart Phone
    10-30-2013 04:54 PM
  3. jhill110's Avatar
    Do you see your apps? If not go to settings /accounts and delete Google. Then add it back.
    Sent From The Galaxy VIA Subspace
    11-02-2013 06:53 AM
  4. raymb1's Avatar
    If your date and time are off, it will cause a problem. As was discussed in another thread, resetting the date and time solved your problem for many on this forum. Later, Ray
    11-02-2013 09:24 AM
  1. Galaxy Note 3 - Region lock.
    By roguetrader in forum Samsung Galaxy Note 3
    Last Post: 11-03-2013, 11:35 AM
  2. Sprint 3rd Quarter 2013 Report
    By Paul627g in forum General Carrier Discussion
    Last Post: 11-03-2013, 07:33 AM
  3. Sprint Galaxy S3 - Is there a master list of safe apps to delete?
    By Drummerboy1975 in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 10-30-2013, 10:06 PM
  4. Replies: 1
    Last Post: 10-30-2013, 11:20 AM
  5. sprint gs4 4.3 update rolling out now
    By slackerjack in forum Samsung Galaxy S4
    Last Post: 10-30-2013, 10:09 AM
