1. 6tr6tr's Avatar
    What's the best stereo bluetooth headset for the Nexus S that's not too expensive and also allows phone calls?
    09-12-2011 03:11 PM
  2. gabbott's Avatar
    I use one made by LG and is carried by Sprint, works pretty well. Believe it was about $65-$70.
    Edit: it is this one:
    http://www.amazon.com/LG-HBS-700-Blu...cUvbUpU1238760
    09-12-2011 04:13 PM
  3. eze036's Avatar
    yep i use the same one for about a yr love it..great sound for calls and music..use it at the gym very lightweight...
    09-12-2011 05:22 PM
  4. 6tr6tr's Avatar
    Is it weird always having that thing around your neck though?
    09-13-2011 12:22 PM
  5. crowbro063's Avatar
    I have a motorola S10 headset. Very lightweigth. Good for the gym and sounds great.
    09-13-2011 12:29 PM
  6. Bujin#IM's Avatar
    I use an old Plantronics Voyager 855, which can be found on ebay. It's great because it can convert from mono to stereo, and also has AVRCP, so you can control your audio from the headset.
    09-16-2011 09:32 AM
