chud
Re: Case or no Case?
if you're ever looking for a change in cases or whatever, the Incipio Feather would "solve" the problem with the monoprice cables because the bottom area of the case is open. You're sacrificing a little drop protection though.I recently purchased a Rearth Ringke case for my Nexus and I like it. I also purchased a Ringbo screen protector for it.
The combo is working out pretty good for me. The only slight issue that I have with the case is the cut out for the USB cable is kind of narrow. The OEM Samsung USB cable fits perfect, but the extra micro USB cables I had from monoprice.com are a bit too thick at the connector. They still plug in, but kind of at an angle which I fear is going to put stress on the micro USB port.
Sent from my Nexus S 4G using Tapatalk
